thanks for the replys nice to hear from you sodapod, mate give it a go i was worried about doing it but if you increase it a bit at a time you wont go wrong as long as you watch the temps and not increase the volts to much you be fine mate.
newbe5 i can give you the settings for mine but like most in this thread will say each cpu is different which is true,what is your vid(find this using cpu-z)mine is a 1.3.
i did it in stages i got to 3.2 on stock settings after this it got a bit more interesting
basically increase fsb in stages post above from keogh will explain how the fsb x multiplyer works example fsb 413x 8 = 3.3ghz but dont go and do that straight away tho increase it to 2.7 first run prime small fft for 30mins or so watch coretemp should stay pretty low for now,only really starts getting toasty at around 3.4 max i got that was around 55c
i didnt need to touch anything till around 3.4ghz but like i said your could be different might be better might be worse,let me know how you get on post back and i will help you as much as i can,or someone herem might add there thoughts setter keogh have helped me really well
also whats your cooling like fans ect i have 8 fans in mine 3 of these is my dominator ram fans.nice and cool in there now lol what ram do you have ect as you didnt say ragarding the ram keep that below its limit.
ps keogh/setter prime is done all is stable and perfect at 3.5ghz
