hi all will need help clocking tommorrow
9 Dec 2006
hi all will need help clocking tommorrow(getting raid to work)
my parts will be here tommorrow
6 - Samsung SpinPoint F1 750GB SATA-II 32MB Cache - OEM
1 - Asus Rampage Formula Intel X48 PCI-Express DDR2 Motherboard
1 - Intel Core 2 Quad Pro Q6600 "Energy Efficient SLACR OEM
1 - Gainward ATI Radeon HD 4870 512MB
2 - Kingston HyperX 2GB (2x1GB) DDR2 PC2-9200C5 1150MHz Dual Channel Kit
1 - Thermaltake ToughPower 850W Modular Power Supply
1 - Zalman CNPS9700-LED CPU Cooler
in my old Silverstone LC17S-C HTPC enclosure
need to get crysis to run at 1900x1080 on my 46" lcd
first question can i use my vista ultimate on my new build and keep my old pc running as well i know your should not but i need to get files off it
second question raid 5 or leave as single drives was thinking of going raid 0 but if one of the 6 drives fail thats a lot of data to loose
thanks
Firstly, wouldn't it have been an idea to save a little more and crossfire your 4870 for such a resolution (Especially in Crysis)
First Question: If you have an OEM copy of vista, the licence isn't supposed to be transferrable, but give it a go, phone them up if you have to, and attempt to convince them you merely upgraded your existing pc.
If you have a Retail copy, you should just be able to activate, and keep the old one running. If you chose to continue running vista on your old machine, I believe you'd have problems with WGA and Windows Update.
Second Question: Raid 5 every time.
hi i am haveing trouble getting my raid 5 working
i can make the array in the raid bios but system bios wont see any drives
help
help
That's not a problem - the system BIOS isn't showing RAID arrays - they pop up elsewhere in the boot sequence.
And you'll pay a terrible price in performance for going RAID5.
so what you use with the system i have 1st post
i have windows installed now with 2 drives in raid 0 and 4 drives in raid 5
I don't find any hit in performance with Raid5, theoretically it should out perform standalone hard drives (controller dependant, of course)
You'll pay a much higher price for going Raid 0 when a drive fails.
where here is what is happening
the raid5 array 4 disks was rebuilding with the windows software and it says disk drive on port3 failed
so what i have done is put the disk drive which was on port 3 on the motherboard on port5 of the motherboard. now it is rebuilding
if i am right the failed disk should move to port5
i need that mutch because i have lots of hd helicopter vids
