Hi all
First time poster and part time reader of the forums and just wanted to get ideas for some small upgrades (read cheap) to my gracefully aging gaming rig. I've stuck my system specs in my sig for all to see, but will go through them in a bit more detail.
Powering the rig atm is a E6600 that I've left at stock for the most of its life but today decided to let it off the leash and OC it to 2.7. It's going through through a Orthos blend test atm (been going for over 4 hours so far with temps ranging from 41-45C). Still on the stock HSF so not wanting to tempt fate and push it any further and is one of the things I know will need to upgrade to get it any higher safely. Any suggestions on a good cooler and compound?
Next up is my GFX card, a HD4850 that replaced a 8800 GTS 640MB I orginally fitted to it when it died unexpectedly. Now theres nothing really around worth upgrading it to IMO other then a HD5800 and I don't have 200 quid spare at hand. OCing is one option to get more out of it but the damn things hot as it is (89C with the fan at full speed) and would require a fair bit of modification.
Next up is my HHD that I feel needs an upgrade after all these years, more so after I benched it with HDtune. It's a WD Caviar SE16 320GB and it maxed out at 65MB/s and figured that was reasonable. Then I ran it on my Media PC with a WD Cavair Blue 160 and 250. Then my jaw droped. 100MB/s??? There must be a mistake, that can't be right. But it was, HDD drive tech moved faster then I expected. So I'm thinking pick up a 500/640 drive but do I go for a WD black/blue or a Samsung F3? Or is there nothing between them and save some money at the the Blue 500?
Cheers
Cheers
