Hello everyone, this is my first ever post so forgive me if it's in the wrong place.
I recently got a new pc:
Q9550
8800gtx dual sli
4gb DDR2
Asus P5N-D
And all was fine until i went into BIOS. I was looking around and found something called jumperfree configuration, so thought i'd look inside, turns out there was an automatic overclocking option, so i thought i'd try it out and see how.. bad it was
, Anyway It had the choice of setting the cpu to 5% 10% 15 or 20%, so i chose 5% to start and then pressed f10 to exit and save...
Now a box appears, usual thing when you change settings and sits there.. for a whole hour, saying 'Do NOT press the rest or power button', so usualy this goes away almost instantly, it stayed for an hour mustve frozen, so i restarted my pc, and then.. no screen.. fans all turn on, leds working, but no startup screen, cant get in bios (tried holding insert, tried holding delete, nothing.
So i thought ok, a simple CMOS reset would fix things, I open the thing up, take out the mobo battery, replace it after about 10-15 mins, and pop the gpu back into place.
Plugged it all in, screen in the same gpu socket as before, but no screen still, the same situation.
I'm really quite worried, this has put me off ever overclocking anything again as the pc was over a grand.
Please any help would be good.
Francis
Q9550
8800gtx dual sli
4gb DDR2
Asus P5N-D
Francis
