Hi all, Merry Christmas! ( although it isn't christmas yet
This might seem like a stupid question, but i'm ok with PC's and stuff but not that good. So I'm thinking of getting this motherboard -
http://www.overclockers.co.uk/showp...P45 (Socket 775) PCI-Express DDR2 Motherboard
Will this support a 9800 GTX? Or a 280 GTX ( for future proof ) I can't spend anymore on that motherboard so getting a better one is out of the question
Also, will it support the Intel Core 2 Duo E8600?
I also want to get this case,
http://www.overclockers.co.uk/showp...WA Shark Aluminium Full Tower - Black (No PSU)
Will this case fit that motherboard in, and also the graphics cards, such as a 9800 GTX or a 280 GTX?
Thanks, I know it might seem like a nooby question, but I just like to make sure
Thanks for you're help!
.This might seem like a stupid question, but i'm ok with PC's and stuff but not that good. So I'm thinking of getting this motherboard -
Ok, just to clarify, the motherboard will work with that Intel E8600 and a 280 GTX, and should hopefully just fit in?
) you won't get full use of the ram unless on a 64bit OS remember
