Hi from sheffield
20 Jul 2010
Sheffield
Hi after creeping round the forum for some time I decided to join:D
I'm just abouit to start my build and will post a progress thread.
Not built a PC before so I hope I learn loads of stuff from this forum
Welcome aboard. :)
Looking forward to seeing your build progress. There’s lots of help around if you need it.
Welcome :). Enjoy your stay.
Welcome to the forums mate!
In regards to your sig, this is what the dons want you to read :)
You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you. The forum Dons/Admins reserve the right to judge individual signatures, particularly those deemed to contain material of an adult or offensive nature. If the Dons/Admins think the signature is unsuitable for a family orientated forum, then it will be removed. If the user then replaces it without making changes, they will be suspended.
Source: FAQ
