Hi guys, little help please?
14 Jul 2013
Hopefully the first post of many :-)
I'm looking to get a gaming rig and have a budget of around £1200 just for the tower. I'll primarily be playing fps games with a focus on Arma 2 and 3.
I've spent hours pouring over the system configurator and weighing up between the options or getting a titan pre built for around the same money. I'm now more confused than ever! My last pc was a win 98 with 8meg of ram lol
I'm torn between the 3gig 7950 or one of the 2gig GTX's which seem to perform with better frame rates.
Sorry for yet another "spec me" thread but I'm completely stumped. Basically, spend my money!
Cheers.
I would recommend one of the 7950's which give you the £150 worth of games. You can sell some of the codes for £10-15 each to make some money back. Can't spec as I'm as work, but will try later.
You happy to build yourself?
So you need everything? Monitor, mouse, K/B, OS?
I wouldn't be confident building myself and I'll be getting all the peripherals off the missus for my birthday bless her! It would need an OS though.
Cheers mate.
Cheers mate.
There are many guides on YouTube on building a PC, you should check out a few videos before ruling it out as you will get a bit more scope with the build.
It seems pretty daunting to begin with but when you see that all the connectors are different sizes and only fit where they're supposed to go it's not as bad as it seems.
I'm actually an electrician so I'd probably be able to have a stab at it! Come to think of it I'd quite enjoy it. Just worried that nothing would happen when I turn it on lol.
On of of that, you can post here with your questions and always request help from someone who is local to you. Alternatively, you can request OcUK to build for you, but this would come at a price.
You'll always hear more horror stories of forums etc... As no one complains when it works but I would imagine failure rates on equipment is pretty slim these days.
Have a search around the forums as there many posts with links to good guides for building a PC and as I've found by trawling through the forums all the guys here are great and always willing to help.
Good luck with the build.
Thanks guys. I'm leaning towards a self build now :-)
TheReaperGuy, is that including VAT? Very reasonable price! On the first boot will the OS look for all the latest drivers or will I be doing a bit of hunting?
Graphics card, motherboard will come with most drivers, however it's best to install the LAN drivers & then get them from manufacturer websites (Catalyst Control Centre, Motherboard drivers, SSD firmware, HDD firmware etc etc) to get the most up to date.
So, I've got a better understanding of which direction the build is going. What are people's views on gfx cards?
I'm not sure whether to go 7950 3gig or a Nvidia 670?
Thanks for the help guys :-)
I've been having issues with the new nVidia drivers as have many others. For this, and the fact you get £150 of free games, it would have to be the 7950.
iceQ if you plan to ever go crossfire in the future, twin frozr, if you won't be.
Reason: The iceQ has a better fan to handle the heat of 2 cards that close together, it is an exhaust fan where as the others aren't so they draw in heat, especially the top card.
well said.
rear Exhausting GPUs are good to have even if your only using one card. Keeps the air flowing the right way. :)
And finally, should I go with the X2 variant? As far as I can tell the core runs 25MHz quicker. Is it worth the extra few quid? It still looks as though it exhausts too?
I really appreciate the help guys.
