Hi guys, need some help or tips or anything that i can do to squeeze even more performance from this memory.. i am having to run the memory in Geardown mode as i cant get T1 command rate to boot at any timings other than 3200 or 3400 anything higher will not boot though i have heard that Gear down mode is faster than disabling it its like T1.5 instead of T2 wich is slower anyway
check out the pictures and tell me if these scores are any good i also managed to get the latecny way down wich helps with Ryzen...
These settings are fully Memtest86 stable even under the 100% hammer test.
also is there any way i can lower this setting TRCDRD, the lowest i can go is 17 when i go 16 i start to get errors showing up under test 6 of memtest86. you will probably have noticed im also running @1.45v voltage i did lots off research on this and BDIE is good for up to 1.5 hell there have been people running 1.55v and up to 1.6v with bdie as there dailys anyway can you guys let me know if something is not quite right with my settings to get more performance anything i can try ? also my guide for tweaking was following the ryzen calculator and lowering a few at a time lol
cheers. guys.
One final note* i also managed to almost get my Infinity fabric clock working in windows @2000mhz but there was a slight problem the audio from my sound card starting crackling/poping when i was listning to music
i figured that i wouldnt peruse going this route cause i was already at the maximum SOC voltage 1.125v though bumping that up from default made a huge difference to the infinity stability i could before not go any higher than 1800mhz infinity fabric due to a AGESA or CPU or BOARD issue but bumping that SOC voltage solved everything almost i mean i rock solid 1933 infinity with no issues with sound or stability but 2000mhz just seems like its on the brink off stability but i didnt want to risk going higher than 1.125v on that SOC as it says maximum on that ryzen calculator then again not sure how far you can actually take that SOC voltage but i wasnt willing to risk it until i do more research on it unless someone knows.
i know lots of question and need PRO`s to answer tham if you can cheers.
cheers. guys.
