HI i bought a new gpu 2 weeks ago and have been having a lot of issues with it.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-117-XF&groupid=701&catid=56&subcat=938
when im playing games (ut3 happens all the time, cod 5 happened once whilst i played for 4 hrs) the screen will suddenly change to vertical multicoloured lines whilst still playing the sound for 5-10 secs. or screen goes black for 5-10 seconds ( usually coloured vertical lines tho). then i need to reboot. there doesnt seem to be any perticular time that this seems to happen and seems completely random. sometimes i get to play for like 2-3 hrs other times it freezes in 10 mins.
i have disabled the onboard (3200) in windows but cant find where to do it in bios.
i have tried different catalyst drivers including the newest 1 released yesterday. each time i install new drivers i have removed the old ones using driver sweeper.
ive run a stability test in furmark for 20 mins to check the temps around 50c is idle
GPU2: GPU Diode (DispIO) 68 °C (154 °F)
GPU2: GPU Diode (MemIO) 74 °C (165 °F)
GPU2: GPU Diode (Shader) 70 °C (158 °F)
this issue of crashing seems to be completely random and seems to becoming more frequently. it has never happened unless playing games and didnt happen for the first few days the card is not over clocked.
do you think its a faulty card or other issues thanks in advance
( sorry for stating the obvious ). But it really does sound like a GPU problem. Have you checked the temps of the card whilst in game ? Does it do this sometimes on desktop? Seems strange that it only does this when under the pressure of a game.
