Hi please take a look and tell me whether everything will go together and fit in this case.
14 Oct 2019
ARCTIC COOLING P14 SILENT BLACK FAN - 140MM X 3
CORSAIR CARBIDE 110R MIDI TOWER ATX CASE - BLACK TEMPERED GLASS
MSI B450 TOMAHAWK MAX (SOCKET AM4) DDR4 ATX MOTHERBOARD
CORSAIR TX550M 550W 80 PLUS GOLD SEMI MODULAR POWER SUPPLY (CP-9020133-UK)
ARCTIC FREEZER 34 ESPORTS DUO RED CPU COOLER - 2 X 120MM
AMD RYZEN 5 3600 SIX CORE 4.2GHZ (SOCKET AM4) PROCESSOR - RETAIL
PATRIOT VIPER STEEL 16GB (2X8GB) DDR4 PC4-28800C17 3600MHZ DUAL CHANNEL KIT (PVS416G360C7K)
I am most concerned about the the size of the case will this one be sufficient once all components are in? Thanks
5700xt red devil
save some cash and better airflow case, along with 650w PSU - specially if your going to OC GPU
matx format saving some cash along with 3200hz ram, just overclock it
My basket at Overclockers UK:
Total: £480.65 (includes shipping: £11.70)
stock fans are fine ^ on both case and CPU personally. if oveclocking CPU then go for it with aftermarket​
Either go with the 3600 or jump to the 3700x imo the 3600x isn't worth it in terms of price performance over the 3600. Stock coolers are fine if your mainly gaming even if running an overclock.
Do you think I should just go with the 3600x instead? Then I haven't got to bother overclocking and the stock heater is slightly better I've heard
to be honest, we just tell users to grab 3600 and leave it be :)
gaming at 1440p your fine. 1080p on a 144hz monitor then wanting to push the most is understandable as it's slower then intel at this resolution
Hi I've just been reading 5700xt have problems playing UE4 games. I think I may invest in a 2070 super instead than have the head ache. Will this fit and be compatible still? Plus will the heating still be good enough? Cheers
yeah be fine .
£40 more then other cheaper RTX2070S designs but triple fan and 2.5 slot design. Also 4 yr warranty registered vs 3 of others . Zotac has 3+2
Total: £870.48 (includes shipping: £10.50)​
monitor able to handle g-sync ? guessing its 120/144hz ultra wide ?
2070 is 5-7fps behind the 5700xt and thats 4-7 frames behind the 2070s
