Hi problems with shuttle
30 Jan 2011
hi, I have a shuttle computer, I am having problems with the grapthics, I have tried onboard grapthics, and the PCI-E card. The monitor flashs when I plug up the monitor too it. I have allready tried the trick where you turn the shuttle on and turn it back off again, and remove the power cable as you got to turn it on and leave it off for 30 seconds, but then it still wont respond.
What are the specs of the shuttle PC?
What sort of flashing is the monitor showing? Are you sure it's not the monitor having problems?
The specs are :
Technical Details:
Product description Shuttle XPC Glamor Series SG31G2
Type PC barebone
Form factor Small form factor
Dimensions (wxdxh) 20 cm x 30 cm x 18.5 cm
Weight 3.3 kg
Processor socket LGA775 Socket
Ram 2 GB DDR2 SDRAM
Storage controller Serial ATA ( Serial ATA-300 ) ; IDE ( ATA-100 )
Hard drive 1tb and 160
radeon pci-e
creative Sound card blaster live
the monitor is a Proview 772 (FAQC470128559)
I dont think it's the monitors as it works on my other pc.
flashing like its trying to load but cannot, on and off, like it does when you disconnect any monitor from it's port.
goth1986
