- 18 Feb 2013
Hi there I joined this forum because I have heard VERY good things about the general level of intelligence and technical expertise some of you hold, my question is probably a very simple one and any help would be greatly recieved. I have an asus rampage formula x48 motherboard of which I am currently enjoying an overclock from 2.66ghz to 3.2ghz on my q9450cpu. My question is this, I have OCZ reaper 1066mhz ram (2x4gig in dual 2x 1gig in sinlge) but do not seem to be able to overclock it (currently running at 400mhz (x2 for ddr2=800mhz?). I would like to know how to run my cpu at 3.4ghz and my ram at 1066mhz, (I have heard of many people acheving this easily), as I am currently saving for a new system and believe this overclock would breath a bit of "new life" into my system during this gap. I have overclocked using the auto level up option in BIOS but get a bit lost when I switch to manual being totally overwhelmed with the numerous options, cpuz says to get my ram at 533 (x2 because it's ddr2 =1066mhz I understand?) by having 5-5-5-15 timings at 1.2v which is not a problem but it says my TRC sould be a 26. I cannot find this option on the settings. I thank you in advance for your consideration (cooling is not an issue). Telling me how to adjust the settings in BIOS would be helpfull as I am clearly no overclocking guru!
