Hi what case would be best for my bundle?
3 Jul 2011
Essex
im buying "Radon Utahraptor" Intel Core i5 2500K 3.30Ghz @ 4.40Ghz Overclocked Bundle - MSI next week when i get paid and i cant decide what case to get.
im looking to spend around £80 max
im looking for a case that has plenty of room for my hd5770 xfire and a ssd 2.5"
so far ive come up with either
Cooler Master CM-690 II Lite Dominator Case
or
Cooler Master HAF 922 Case
but im open to suggestions :D
this is my first real build from scratch so im abit noob and i dont want to make any mistakes with my order
Other options:
Fractal Design Define R3 Midi Tower Case - Black Pearl
Lancool Dragon-Lord PC-K62 Mid Tower Case with Window - Black
Oddly enough I have both of the cases you mentioned.
For cooling the HAF922 is the best. the 200mm fan on top pulls out a lot of air and it has a lot of space in it too. Oh and the cable management is top notch!
PS: Thanks for changing the colour of the text!!
Thankyou and your welcome :D ill take a look at these suggested cases thankyou very much
what about this one? would it all fit into this Zalman Z9 Plus Tower Case with Fan Controller
i really like the look of it too
All your bits will fit in there just fine. The reference 5770's are only about 22cm long IIRC, so there will be no problem there as it has 29cm of clearance.
I've never played with one so I can't say much more.
But you can have a read through this.
thankyou mate for being so helpful :D
