Generally a faster dual core CPU would be better for gaming and it's also cheaper. I've got an overclocked E8400 and I think it's a fantastic CPU, definitely happy with mine.
My little bro had that case (kandalf) and wasn't impressed, mainly the fact it was too big and didn't need the space, also the cooling wasn't as good as his current case (antec 900). In my opinion I thought it looked cheap n tacky and far too big! But it's your case, if you like it then that's what you go with, since you're the one looking at it all the time
Do you need the extra features on the P45 deluxe? You could save a bit of money and go for the Pro version, it'll still support crossfire and should be good enough for a decent overclock
Well you have all put me off the case now lol but thanks for the advice
The people who review them, must be getting a good back hander for telling porky pies (lies)
Well i just want a fast good clockable machine, for the net and games, nothing else
. i read the deluxe was a better clocker then the pro, and better gaming board ?. maybe i'm gullible with what i read.
i guess i don't need extra features, just something fast,
clocks the E8400 to 4+
and don't struggle ? help me out here
i guess i want the best
but if i can save money somewhere that will give 2% less results, then great/ any advice please
is deluxe really worth it ?
would i be best to change over to the pro ?
Get the XFX 4870 fasterthanaspeedingbullet edition - it's only £17 more.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-115-XF
Surley it's just been overclocked higher?. i rather save £17 and clock it my self
It used to be faster for gaming but it's not anymore.
Fastest at 1600x res+ in this order:
Intel i7 920 & AMD X3 720
Just a shade slower AMD X4 940 & E8500.
The AMD X3 offers i7 beating gaming performance and is the cheapest chip here, it's a bargain, if however you're desperate for a Quad (no real reason currently) then one of the others will be just fine, at high rez they are all within a few fps of each other - it might suprise you to see the cheap-o Tri-core/X3 AMD beating them all on most game benchmarks (check out guru3d.com for an example).
I don't have an old chip to update the bios if i was to go the AMD X3 720 rout.
I mean, if it's only 2 or 3 FPS in games, compared to the AMD X4 940 clocked @ say 3.6, then wouldn't i be better off going with the AMD setup ?
That's only of course if it's very minimal margain ? i don't know 100%
i just want to make the right choice. as i only upgrade every 3 years lol
I be playing with everything maxed out (as i like it to look good) @ 1600x + res
Cheers lads.
P.s how comes you went for a AMD X4 940 ?
