Hidden gems on Steam?
If you like offroad racing, there's that motormax extreme game, which I really enjoyed. More of an offroading sim, but a good laugh for cheap.
EDIT: Steam does not have AIDS
Does steam really kill germs?
You bet it does. Besides its amazing cleaning power and efficiency, steam cleaning also kills bacteria, viruses, molds and other micro-organisms.
How does steam kill germs?
To sanitize, aim the steam at the surface to reach a minimum of 175ºF for a minimum of five seconds at a close range. The temperature of the steam at ½ inch from the nozzle of Steam steam cleaners is actually much higher- more like 220ºF.
Yes, but can you prove it?
In our independent lab tests against a leading household countertop cleaner, Steamwas almost twice as effective at eliminating bacteria and other microorganisms (kill rate of 65% versus 36%). Against a leading toilet bowl cleaner, Steam again outperformed the leading brand (kill rate 97% versus 85%). In both instances the lab noted that longer exposure to steam heat results in higher kill rates.
The lab further noted: “Scientific literature also indicates that steam heat is effective in the removal of bacterial biofilms.
