I right clicked on one of the folders on my desktop and in the properties dialogue box there was a checkbox for 'Hidden' below the Read Only option. Worth a shot, never used it personally though. If the folder becomes invisible to you as well, don't blame me
[edit] Aah just tried it. Looks like it can make the folders disappear for you as well if you dont have 'Show hidden files and folders' enabled.
open any folder > tools > folder options > view tab > Show hidden files and folders or change this to Do not show hidden files and folders for the hidden thing to work.
I don't use mutliple accounts on the one PC so don't know if this option can vary by user-account, ie. show hidden files on account A and dont show hidden files on Account B.
[2nd edit] just a note, this is probably a long winded way around so probably only a temp fix
[3rd edit] phew, maybe I should just leave the edit window open for a few hours until I can't think of anything else:
http://www.pcanswers.co.uk/tips/default.asp?pagetypeid=2&articleid=31077&subsectionid=616
was reading that link and thought maybe all the user accounts are Admins, what about bumping them down to plain old users, or messing with some of the options mentioned in the article to see what comes about
OK i'm leaving this thread now to save on the edits
