Hiding Power Cables Etc Under Desk
28 Jun 2005
Anyone got any tips for hiding power cables, keyboard leads etc beneath a desk? I've got a few PCs and am trying to get away from the snake pit that usually sits under my desk gathering dust. I'm thinking something like a large cable-tie which then somehow sticks to the underside of the desk. Any ideas?
You can get cable tie bases - these stick to surfaces and the cable tie feeds through it. Not sure how big they make them though - I've only used small ones before.
You might be able to find a long piece of rectangular plastic, with one side cut off, that side would then be stuck/screwed to the underneath of the desk with the wires all neatly going from the pc etc > through the plastic section and down to the plugs.
