Could someone recommend a case with high air flow than can fit a Hard rock pro 2 (Hard rock)
and a GTX 590. I have an antec 183 p183 and it has minimal space between the heat sink and the side of the case (a few mm at most). I was thinking about a Aerocool case but was unsure as to if there would be enough space for the side fans. If this would not fit does anyone have any other ideas, the more airflow the better.
