High Airflow Case
Caporegime
8 Sep 2005
Norrbotten, Sweden.
I currently have a Antec p160 with 3 hard drives
I'm looking for a new case with much much greater airflow intake and exhausting.
It has gotten to the point where i have had to take off the side panel (i know this defeats the point but its got that bad !)
I was thinking about getting a 2nd 4870 and running them crossfire, but ive decided i need to solve the heat problems 1st
I've looked at the Antec 900 and 902 - and this has also been recommended by 2 people i know
Could anyone advise me on other (cheaper maybe) options with as much airflow potential as the Antec?
Must have 2 intakes on front optional side maybe ? and preferably a top exhaust and rear
IM not too bothered if it sounds like a jumbo jet ;)
100 max budget but ideally as low as 50 would be nice... if a similar solution can be found !!!!
Antec 300?
Got 2 front intakes, the option for a side fan, a large top exhaust and rear too.
Might be a little tight with the 3 hdd's, but you could always place one up in the 5.25 bays.
Here it is with 2 hdd's installed to give you an idea of size...
Thanks - picture appreciated.
Any more suggestions ? Looks a bit more budget (similar to p160 same era nearly i guess) than i expected but i guess you get what you pay for.
