I am planning different high-availability scenarios for a customer, with a new server (either SBS Std or Server 08 Std + hosted Exchange) and I imagine it will be based around Hyper-V. The customer is suggesting having a secondary server that they can fail over to. I'm looking for a solution that will replicate the Hyper-V setup on the primary server in real-time onto a secondary stored in a separate secured location in their warehouse (LAN link, it won't be geographically separate). The solution should be as easy to fail over as possible, even to the extend that one of their (reasonably tech-minded) staff could perhaps perform the operation; this part isn't a critical requirement but would be nice to have.
I have had a quick look and am looking at DoubleTake, SteelEye, ViceVersa Pro, but would like to hear what some of you have worked with in this environment.
Sometimes I think that the cost of this can be prohibitive versus a 2-Hr response, 5-yr warranty with the likes of Dell, and redundant disks and power supplies built in. The customer will be purchasing a new server anyhow and all of this will be in place (with the exception of changing the 2-Hr to either 4-hr or NBD). Your opinions welcomed
