So I just replaced my old motherboard, installation was easy and I applied new thermal paste (artic ceramique 2) and out my freezer 7 pro back on. Everything seemed fine but when I got to the bios I saw the temp was over 50 degrees. I tryed again and remounted with new paste and no change and it wont boot into windows it BSOD while booting so its defo overheating, im conecerned as Im not sure if the freezer 7 is AM3 compatible, the mounting on it didnt fit perfectly on the socket and the AM3+ socket seems slightly taller so I dont know if its making good contact with the CPU.
Do you think the freezer 7 is causing the problem, its screwed in as tight as i can go
