Hey guys
MB: Gigabyte GA-Z97X-SLI
CPU: QuadCore Intel Core i7-4790, 3800 MHz (38 x 100)
CPU cooler: Hydro H60
PSU: Super Flower Leadex II 1200W
My PC died in the middle of gaming, which was followed by a bang. Following the smell, I determined it was my six years old 650W Leadex power supply. I decided to replace it and since I know close to nothing about this stuff I got myself one that looked pretty much the same but with 1200W on it.
I replaced the old one(650W) for the new one(1200W), changed the cables, changed the battery on the MB (re-setting BIOS), started the whole thing up and it's working pretty much the same apart from one tiny problem - the CPU temperatures seem to be quite high, idle or not.
When I start/shut down the PC, the CPU fan goes full speed then it calms down but if I disturb the CPU by opening any application, it revs up again. It's as if it was in a constant state of high RPM and it just goes higher. With my old PSU, it never behaved like this. Temps weren't that high either, as far as I know.
I thought that when the old PSU died, this might've caused some damage to the MB or CPU, or could re-setting the BIOS be responsible? Any advice would be appreciated.
I took some screenshots of some stuff for you tech-savvy folk. I reapplied the thermal paste on the CPU, just in case. It did bring the temps down by few points (compared to the screenshots) but it still behaves the same.
Idle(just background apps): https://ibb.co/Hd4Mmtc
"Stressed" (5 minutes of gaming): https://ibb.co/L0RxZkX
