- 12 Mar 2011
- Rainham, Kent
I was just wondering if my high CPU temps could be due to a faulty PSU? I have recently just bought the following
Asrock m3a770de mobo
amd 1090t cpu
hd 5770 gpu
Artic Cooling freezer 7 pro rev 2 4gb ocz gold 1333mhz
all of which are new but I have a used 700w PSU powering it all.
Just wondering if the PSU is a bit faulty if it could raise my CPU temps as i have reseated my heatsink about 5 times now and now matter how i do it i get the same temp.
Also when playing games like Crysis 2 and Medal of Honor my PC just freezes up and i have to restart using the reset button.
Running prime95 for about 5min my CPUTIN is 70c and each core temp will be about 61c. I don't let it go any higher as i am afraid of doing any damage.
The air flow is fine as i have 4 80mm on the side panel. 120mm at the front and rear and a 140mm on the top.
Any help is greatly appreciate.
Regards,
Ben
amd 1090t cpu
hd 5770 gpu
Regards,
Ben
