http://img72.imageshack.us/img72/7812/tempsetc.jpg - idle
At 100% load im at around 78-80 degrees.
Im using this cpu cooler http://www.overclockers.co.uk/showproduct.php?prodid=HS-070-AK which has 4 pipes directly touching the cpu http://images.bit-tech.net/content_images/2010/03/akasa-nero-s-cpu-cooler-review/7.jpg similar to that, i used the line method with my mx-3 thermal paste where you put a small line inbetween each pipe
