High CPU temps
6 Jul 2006
England, Stafford
Hi at the moment i ma encoding some video on my laptop and it is running very hot, between 85-90, is this bad for it, its running normal with no problems
can you plse give your advise
i have a sony sz2m/b laptop if that helps
What CPU, and what are you measuring the temps with (this last bit is important)? That does sound very hot...
edit: looks like a core duo T2300 - try using Intel TAT to measure the temps...
well just tryed tat and im geting between 88-90 should i be worried, tho i do know that encoding video is very cpu intesive
