Hello,
My CPU's idle temperatures are somewhat high (37C-45C) with an ambient temperature of around 22C. Also, as soon as a run Prime95 the temps run over 100C. The CPU is NOT overclocked, and the case temperatures are OK, as my AIO GPU hovers around 35C idle (but GPUs are expected to run slightly hotter than CPUs)
Part list :
** Link removed, contains competitors **
Things I've done to try and fix this but to no success:
I have replaced my Kraken X61 with a new one.
Applied MX-4 instead of the stock thermal paste.
Additional Info:
3x Cougar Vortex fans are mounted on the front as intake
2x Noctua NF-A14 are mounted on the top as exhaust in pull configuration with the Kraken X61 radiator
1x Noctua NF-F12 is mounted on the rear as exhaust in pull configuration with the Kraken X31 radiator.
Thanks in advance for the help
Part list :
Additional Info:
