Howdo,
I have a 965BE which is currently cooled by a Titan Fenrir. Does OK but you can only point the fan downwards, straight at my graphics card, so I can only run it at 3.7ghz, even though I know it's capable of more.
I'm going to add another 5830 because they're dog cheap on ebay at the moment, and because I've always wanted 2 graphics cards. Because of the way the CPU cooler is pointing, it's gonna get toasty.
I'm not going with custom cooling. I only have an Antec 300 so I need something that will fit and keep everything cool.
The 5830s have a 5870 cooler which on my current single one never goes over about 35% fan speed, so feeding them warm air would be fine.
Sooo, that got me thinking, how about one of these? The rad will fit in the front, but I can't find out how long the tubes are so I've got no idea if they'll reach.
The other option I can see is the Noctua D14, but ONLY if this can be mounted east-west on an AM3 socket.
Any other options or advice? Cheers guys. Whatever I buy should have the scope for cooling a maxed out 1100T if possible!
