Hi Guys,
I'm sure there are hundreds of these posts so I really appreciate the input anyone has
My current system is giving me grief - so as it's near two years old it's time to replace (i7 920, Asus Rampage II and a 295GTX).
My thoughts on components are below with the queries to follow:
CPU: Intel i7 980X
Cooler: Corsair H50-1
Mobo: Asus X58 Sabertooth
RAM: Corsair Dominator GT 6GB 1866MHz (CMT6GX3M3A1866C9)
Case: Corsair Obsidian 800D
PSU: Corsair Pro AX850
GFX: ATI 5970
HDD: Crucial RealSSD C300
Ok now the queries
What, if anything, would you change on the above?
Is the RAM suitable for the Sabertooth board as it's not immediately listed on the QVL?
I've read that the Corsair Pro PSU's have a really short 8pin mobo connector as per the user reviews? Is there a better PSU that would support the above and fit nicely into the Obsidian case?
I'm aware the AMD 6000 cards are around the corner but I'm not sure if it's worth holding off? Probably a gamble either way but I believe they still use the 40nm chip so in regards to 'bang for buck' I'm not sure if it will surpass the current 5970?
As for system use it is a gaming/multimedia rig, with MoH and Black ops round the corner it's very much na FPS setup
Oh and I'm ashamed to admit that I play way to much WoW!
My current system is giving me grief - so as it's near two years old it's time to replace (i7 920, Asus Rampage II and a 295GTX).My thoughts on components are below with the queries to follow:
CPU: Intel i7 980X
GFX: ATI 5970
Ok now the queries
