As I am waiting for nVidia Pascal (I will use a spare card in the mean time), I have not listed a gfx card or monitor in this build. I have read for hours about what should work together and I've looked at the motherboard manufacturers website to ensure memory compatibility etc so hopefully I'm all good with this going forward.
Motherboard: Gigabyte GA-Z170X-Gaming G1
The reason I picked this was because of the dual m.2 ports and it's one of the few boards with a PLX PCIe chip and should be compatible with 7th gen i7 chips (thus why I am not going down the X99 route)
Memory: G.SKILL TridentZ Series F4-3866C18Q-16GTZ 16GB DDR4 3866 MHz
Fastest RAM that I know is compatible with the motherboard.
CPU: i7 6700K
This is a gaming PC mainly, pretty standard.
CPU cooler: Corsair H110i GT
I'll likely overclock the processor very slightly using the built in motherboard options - nothing crazy (water cooling would be overkill)
HDD: 2 * Samsung 950 Pro
Super quick, two for RAID (I presume you can RAID the M2's on this motherboard? Does anyone know?)
PSU: Corsair AX1200i
Highly rated PSU with enough juice to power whatever SLI config I throw at it (I probably won't go more than dual at this stage).
Case: Phanteks Enthoo Primo Full Tower
More than enough room, will support huge graphics cards (once a certain panel is removed), great reviews and fits under the office desk (Cosmos 2 Ultra won't fit).
I'm ready to buy all of this stuff but just wanting to make sure I haven't missed anything before I throw a lot of money at the wall.
Cheers.
CPU: i7 6700K
Cheers.
