Hey guys,
I'm looking to put together the following build in the next month. I've went for a pretty high end build I just don't know if the full CPU + GPU loop is worth it.
I am really keen on a really quiet system and will be definitely water-cooling the CPU just not sure on the GPU. How noisy are these types of cards?
Spec:
YOUR BASKET
2 x Inno3D GeForce GTX 780Ti 3072MB GDDR5 PCI-Express Graphics Card (N78T-1DDN-L5HS) £479.99 (£959.98)
1 x Gigabyte Z97X-Gaming G1 Intel Z97 (Socket 1150) DDR3 ATX Motherboard £259.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - OEM £245.99
1 x Phanteks Enthoo Primo Full Tower Case - White Edition £199.99
1 x SuperFlower Leadex Platinum 1000W Fully Modular "80 Plus Platinum" Power Supply - White £161.99
1 x TeamGroup Xtreem LV "Frost Edition" 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit £129.95
2 x Samsung 128GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD128BW) £115.99 (£231.98)
2 x XSPC Razor GTX Titan / 780 / 780Ti GPU Waterblock £94.99 (£189.98)
1 x Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD £79.99
1 x Microsoft Windows 8.1 64-Bit DVD - OEM (WN7-00614) £74.99
1 x XSPC D5 Vario (Body + Screwring) £59.99
1 x XSPC RayStorm CPU WaterBlock (Intel) £51.98
1 x XSPC Acrylic Dual 5.25" Reservoir for Laing D5 £49.99
2 x XSPC Razor GTX Titan / 780 / 780Ti / 770 Backplate £24.98 (£49.96)
8 x Noiseblocker NB-eLoop Fan B12-3 - 120mm £13.99 (£111.92)
1 x Arctic Cooling MX-4 Thermal Compound (4g) £8.99
5 x Monsoon 16/10mm (OD 5/8) Rotary 90° - Matte Black £8.69 (£43.45)
5 x Monsoon 16/10mm (OD 5/8) Rotary 45° - Matte Black £8.69 (£43.45)
2 x Mayhems X1 Clear Premixed Watercooling Fluid 1L £7.99 (£15.98)
1 x XSPC Hose Cutter (0-25mm) £6.95
3 x Primochill Primoflex Advanced Tubing 16/10 - Black £5.99 (£17.97)
1 x XSPC Dual Bayres/Pump V4 Faceplate Pack (White) £4.99
1 x XSPC PSU Bridging Connector (24 Pin) £1.3
Total : £3,021.97 (includes shipping : £16.85).
Any opinions are welcome.
Spec:
YOUR BASKET
and yes, it'll be more than sufficient
