High end water cooling
Suspended
19 May 2003
I have just ordered the last parts of my system I have been saving up for, and I thought the next thing I would start planning on would be a water cooling set up to go with it.
I will be cooling a Core 2 Duo e6600, two 8800gtx in SLI, and it will be housed in an Akasa Eclipse case. Im going to set my budget at around 300 pounds, but am willing to go slightly over.
Basically, can anyone reccomend some high end, custom water cooling that they think would work well with my sytem. Emphasis is on cooling as I will be overclocking as much as possible.
Swiftech Storm for your cpu block
Thermochill pa120.3 for your rad
DDC ultra with an alphacool top for your pump
t-line or res, your choice, no effect on performance
1/2 or 7/16 for your tubing
Cannot give you advice on the gpu blocks as there are no real comparisons on the market with them being so new.
Sounds good.
Would having the watercooling in an external Radbox give significantly better performance over having it internally in the case?
If your'e case has good air flow, no you won't see a significant improvement. If it doesn't you might see some improvement but the main benefit of an external box is that you can have a 120.3 radiator without much troubles though I think you might be able to fit in an Eclipse without any trouble but someone would need to confirm that.
Jokester
Jokester
The pa120.3 will not fit inside an eclipse, however, it can be mounted on the top without any problems at all.
i've done the same with my BIX3, external aint as pretty but it achieves better results and if the rad happens to leak outside theres much less drama.
my cases don't goto LAN's it's never a problem.
