Hi folks
just finished a new build into a specialist 3 unit music case.... powers up nicely, all working. But - first thing I do with a new build is sit and watch the POST/BIOS closely to see any potentials... and my Core i5 is sitting at 53 degrees C at idle. Seems high to me, especially with a decent cooler on board.
Two things to note... firstly, the case is fairly small, but has two extra system fans to promote throughput. There's about an inch over the top of the CPU fan, but there's good airflow in there.
Secondly, the Mobo is a Gigabyte GA-P55-US3L and the cooler is an Arctic Cooling Alpine 11 Pro. I notice that the CPU cooler mount only fits one way - otherwise, the plastic sides foul the RAM slots - and that the cooler itself is a very snug fit against the RAM and the row of capacitors alongside the chip. Now, my last build was a Core Duo, so I'm unfamiliar with socket 1156, but this seems a little unusual. Having said that, I'm sure the cooler is sitting well on top of the CPU. The Alpine Pro comes precoated with thermal paste, and it's that which I've used.
Could this be a board incompatibility with this cooler - is it supposed to be that snug, and is my i5 running too hot, considering that I haven't even got as far as loading up the OS yet?
I think the answer is yes and yes, but before I head back to OCUK and ask their advice, I wondered if any of you with i5's see something similar in your initial testing..
Thanks in advance...
