High Idle Temp & Clocks - HD7950
18 Nov 2011
Kent
Afternoon,
My 7950 is currently idling at 40-45. I recently upgraded to Windows 10 from Windows 7. In Windows 7 the idle would never go above 32-33.
I noticed that the clock speeds for core and memory are not idling like they used to. Its sits at 500 core and 1250 on the memory. I'm sure it used to idle at 300 & 150. GPU usage sits at 0%
Single monitor setup and running the latest drivers if that helps.
Any ideas?
Thanks
