High idle temps on Q6600
8 Jan 2007
Essex, Canvey Island
My Q6600 has been on 3.2 for a few months now with no problems what so ever on default volts (1.26500) but I don't no whether it is my room that is making the inside of my PC so hot. I must admit my room is boiling hot, and in the winter my Q6600 was idling around 19-25c. The PC is currently under the opened window and heatsink is Zalman CNPS9700 at the lowest possible speed. Case is Lian Li PC-7 SE-B III Black Midi Tower cooled by 3 Noctua NF-P12s.
idle temps:
temp1: 46c
temp2: 35c
core1: 44c
core2: 44c
core3: 45c
core4: 44c
Hard Drives: 35c
GFX: 52c
Full Load: 30 min testing
core1: 58c
core2: 57c
core3: 58c
core4: 57c
Hard Drives: 35c
GFX: 53c
I have resat the heatsink a few times and replaced the TIM but only reduces the temps by a mere few degrees. Any suggestions? Maybe a new heatsink?
Lewis
Idle temps mean very little.
Your load temps are grand, and that's what matters.
yeh dont worry about idle as mine are similar on my 6550 at the mo...
Your load temps are quality though so i'd push it even further :)
Yeah i've had it at 3.6 quite easily before - 9x400. I just thought my idle temps would be at least in the 30's since the vid is lowish.
