High idle temps Ryzen 5 3600
4 Feb 2018
i upgraded my GPU and added a SSD into my pc this afternoon, on booting up my pc after i finished installing everything i noticed that my cpu fan was really loud 1900rpm and my cpu temp was at 64°c im using the windows balanced power plan
my bios and chipset drivers are up to date
the other temps are all in the 30s
CPU: Ryzen 5 3600
CPU Cooler: Wrait Stealth
RAM: Corsair Vengance RGB Pro 16GB
GPU: Saphire Pulse RX 5600XT
PSU: Koolink Enclave 500Watt 80 + Gold
Case fans: 4 Corsair LL120 RGB Fans 3 Intake on the front 1 Exhaust on the Back
Case:Fractal Design Meshify C Mini
I don't know how to attach screenshots from HWMonitor if someone tells me how i will add them
C64
C64
16 Mar 2007
London
Use the 1usmus power plan for ryzen might lower it a tad but yea they are toasty chips
I cant even run prime on mine on a noctua d14 it will hit 90c under prime loads, gaming it stays 60's though
OP
4 Feb 2018
What cooler would yoy recommend to get
I was looking at getting
a Corsair Hydro 100i RGB Platinum because already have a commander pro setup for the fans
27 Jul 2020
Do you have epic games launcher on your pc. I was getting high temps on idle and apparently the launcher is doing this to some AMD cpus. If you do try closing it out of background and look at temps.
V F
V F
13 Aug 2003
UK
It does it to Intel as well.
30 Jan 2005
Inverness
I have had 3 3600 CPUs 2 of them ran hot like low 80s with a 120 AIO or 120 tower cooler while stress testing the third one was about 10c cooler with the same settings. I think a lot of them are just hot I don't think it does them any harm but I didn't really like it. The 3700Xs I've had have both been cooler.
