High idle temps with H50
10 Aug 2005
Hi All,
I have an i7 920 OC'ed to 4GHZ with a H50. The i7 was bought as part of a OC bundle from OCUK and has been rock solid.
Yesterday I was encored some movies, something that I do all the time, and the PC blue screened for the first time ever.
I put it down as a one off ever and tried again but this time the machine hung after 20mins.
That's when I checked my temps. Two of the cores are idling around 49-52c and the other two are around 44-47c.
As soon as I run Prime95 the temps jump up to 90c also instantly and two of the cores hit 99c within 5mins, before I stop the test.
Nothing has changed in my machine, airflow is very good.
I have the two standard corsair fans, one blowing air into the motherboard area and one blowing onto the hard drives.
I have three enermax flows at the top of the case set to exhaust.
I have another enermax high CFM fan set as an intake on the rad.
I am just worried that the H50 is failing somehow which explains why it is not cooling the CPU properly but I would appreciate any advice for you guys.
I was thinking of change the fan on the H50 to exhaust instead as my 5870 exhausts into the case and also I have 4 hard drives which may be adding heat to the case.
I am just concerned at the sudden increase in my temps as I have not change anything on the machine for 3months or so and it has always been very stable.
Might be a obvious question but are you sure you have the pump plugged into a 12v header? If not it'll run slower and affect performance.
Download this and look at "AUXFANIN0" it should be called and make sure its @ 1400rpm or there about, if not then the pump isn't getting enough juice.
Also the Corsair fans that come with the H50 ain't much good, especially on an i7 @ 4GHz doesn't seem to be the ideal setup, sounds like it isn't getting enough airflow to cool it (if the pump is in the correct header)
Thanks for the reply mate.
The pump is connected to CPU FAN2 on the my motherboard, which is 12v but I will confirm the speed tonight when I get home tonight.
I am not using the corsair fan that come with the RAD, I swapped that for a Enermax magma fan, which is a high CFM, low noise fan and that has been working great.
I have ordered another Magma fan and will add it to the H50 in push/pull and set the fans to exhaust to hopefully improve the temps.
I will also remove the thermal paste that came with the H50 and apply some artic silver instead. If that doesn't make a difference then it may point to a faulty pump.
Normally the cpu fan header will regulate speed based on the temprature of the cpu so you wont be getting constant 12 volts. It should be attached to a system fan header.
Actually I just checked my manual and I have connected the pump to the CHA_FAN not the CPU_FAN so that should be fine.
The fan for the RAD is connected to my fan controller but it set to max speed.
