Hi there!
My Phenom 965BE (stock cooled) seems to have rather high idle temps, around 55 Celsium. Here in Greece it's 24-25 in the room, a bit more outside.
Normally i'd think it's the #$@% stock cooler that came with the CPU, but i had to reconsider when i noticed that, under heavy load, temps didn't surpass 62, that is only 5-7 Celsium higher than idle! I checked with Coretemp and Speedfan.
What should i do? Is this dangerous?
Ignore Idle temps and do nothing?
Replace stock cooler?
Open case and check if everything is seated correctly?
Re-apply thermal paste?
Many thanks!
Many thanks!
