Ok, so I have optimized defaults running on my Asus ROG Hero, which sets the VCORE to 1.136 for an overclock to 3.9ghz.
I don't believe there's any power saving adaptive voltage whatever set, as the VCORE is at 1.120-1.136 all the time.
However, my idle temps are 40 degrees. I've got an H80i installed at the moment. Each core is actually 48-49 degrees, but the main CPU temp is reported as 40 degrees in Hardware Monitor.
This doesn't change regardless of what my fan speeds are on the H80i (both of them are set to intake, which I believe that's right?). Within seconds my temps jump to 80 degrees on Prime 95, and each individual core reaches 90 degrees or there abouts.
Again, this doesn't change regardless of speeds (low or high).
I've added a screenshot of what it looks like at idle:
Any idea what's going on?
,haswell is hot anyway
