- 18 Aug 2013
Hi
Im having an issue with a ryzen 3600x cooled by a lian li 360mm water cooler. It used to run fine and has done for about 10 months with idle temps of low 30s, now the idle temps are around 60 degrees. When gaming it tops 80 degrees.
On the bios I've got the cooler itself set up as a water pump, on standard mode which seems to stay at about 2500rpm. The intake filter is clean and it's in a lian li 011d with three Noctua fans as intake on the bottom, the radiator is side mounted with the pipes going into the top so the pump should never run dry. When I set the pump to performance mode or full speed it's definitely working with a faint whirring noise. On standard mode I can't really hear it over the quiet case fans when idling, it's not got any louder over its life so I would be surprised if the pump is causing this.
I'm thinking re paste it first as I used the paste that came on the cooler? After that i can't see anything else being a problem
