I have recently overclocked my new system (Intel i5 2500k) and have done a number of stress tests which show that my system is running stable. (One of the results of the stress tests can be seen below).
In the tests my VCore would be around 1.34 - 1.38 which is fine for running at full load.
I have noticed that even when my computer clocks down to 1.6Mhz thanks to turbo boost my VCore still stay around 1.34. Why is this and how can I fix it?
I have posted my current BIOS settings below and have tried a few little things to get the VCore better but this causes my system to become unstable and bluescreen.
Thanks for any feedback!
Intel Burn Test results:
Current BIOS config on Gigabyte Z68XP-UD3P motherboard:
Frequency Settings
CPU CLOCK - 33X
BCLK - ( DISABLED ) left at default 100mhz
EXTREME MEMORY PROFILE XMP - ( PROFILE 1 )
SYSTEM MEMORY MULTI - ( AUTO )
Advanced CPU Settings
PWM Frequency Control: Auto
CPU Over Current Protection: Auto
Internal CPU PLL Overvoltage: Enabled
Real-Time Ratio Chnaged In OS: Disabled
Turbo Ration: 45 (All)
Turbo Power Limit: 300
Core Current Limit: 300
CPU Cores Enabled: All
CPU Enhanced Halt (C1E): Auto
C3/C6 State Support: Auto
CPU Thermal Monitor: Disabled
CPU EIST Function: Auto
Bi-Directional PROCHOT
Advanced Memory Settings
Extreme Memory Profile: Profile1
System Memory Multiplier: Auto
DRAM Timing Selectable: Auto
Channel Interleaving: Auto
Rank Interleaving: Auto
Performance Enhance: Standard
Advanced Voltage Settings
Multi-Steps Load-Line: 6
VCore: 1.330
Dynamic Vcore: Auto
QPI/Vtt Voltage: 1.190
System Agent Voltage: Auto
Graphics Core Voltage: Auto
Graphics Core: Auto
Graphics DVID: Auto
CPU PLL: 1.800
DRAM Voltage: 1.600
Misc Settings
ISOCHRONOUS SUPPORT [ ENABLED ]
VIRTUALIZATION TECH [ ENABLED ]
Power Management
HPET SUPPORT [ ENABLED ]
HPET MODE [ 64BIT ] - 64bit windows versions
, Thanks for the feedback!
, Is my first custom build so you can't blame me XD
