High/Low Density?
7 Mar 2005
Wolverhampton
Hi all.
I have a very old pc here from someone at work. It's currently running an old 850mhz CPU with 128MB RAM !
I've been looking at putting 512MB in. There seems to be two types, high and low density ram. Which one do i go for?
I remember getting some ages ago and it wouldn't read half the SDRam i bought.
Thanks,
Adam.
High density DDR was the cheap tripe that didn't work in half the motherboards (nForce chipsets hated it), so I wouldn't be surprised if it was the same for SDRAM.
I would go for low density if possible.
