High performance 280mm AIO
11 Jul 2003
Telford//west mids
Hi I'm looking to move to a AIO for my 12600kf can I have some recommendations please.
For me it's choice between the Kraken X63 or the Arctic Freezer II
I have a previous gen X62 on my 12700K and it's runs cool and quiet. Some peeps don't like the CAM software that goes with the NZXT coolers though.
Arctic Freezer looks simpler to control as it appears to have 1 RGB header and 1 PWM/FAN pump header.
Also keep one eye on the EK 360 Basic or the D-RGB one.
Very quiet pump and the fans are decent, only need to keep them at 40% to keep them virtually quiet.
Also, pump and Fans controlled separately.
Be careful on the arctic though, what OcUK and the listing doesn’t tell you is that it doesn’t come with the 1700 mounting bracket and you need it separately.
Got a 420 from another place and it came with a 1700 kit, before that I ordered one from artic as I had the 12600kf cpu, they send one free of charge.
I know they send it FOC it’s just annoying that it’s sold as being compatible and doesn’t ship with the correct equipment, you need to order separately.
