High pitched noise CPU/Motherboard
20 May 2010
Hello. I put together a new build just last week with the following parts.
Intel Core i5-4690K 3.50GHz (Devil's Canyon)
Gigabyte Z97X-Gaming 5 Intel Z97
MSI Radeon R9 280 Gaming 3072MB GDDR5
TeamGroup Elite Black 8GB (2x4GB)
SuperFlower Amazon 450W "80 Plus Bronze" Power Supply
Raijintek Themis Direct Contact CPU Cooler
Ever since putting it together, there's been a really high pitched 'squealing' noise coming from inside the case. I've not been able to pin-point the exact location of where the noise is coming from, but definitely seems to be around the CPU area. When I open applications up or game, the noise gets louder and unbearable. When idle it still does it, but not as much.
I've heard this could be 'coil whine' but I've been using the same PSU and GPU and cooler from before and it never used to make this noise. I've tried disabling speedstep and other c-states, but nothing changed. Possibly i'm lacking PSU power? Hopefully someone knows more or can help, thanks.
With this power supply no wonder you have issues, as this card requires at least ~550W. Remove the GPU and see if you have high pitch noise then.
There's a chance the squealing noise is being caused by the sticker on the CPU cooler fan being a bit loose and catching the heatsink as it spins. Could be something else of course but worth checking. I've had "a" squealing noise made by a loose fan sticker in the past.
It definitely isn't coming from the PSU, more like the CPU/Motherboard area. Is it possible to stop my fan with a finger to see if that's the cause?
Sounds like coil whine to me, it can happen after some time.
Load up a game/benchmark where you get a mass amount of FPS and you'll notice it get louder, the first benchmark from 3DMark is a good test.
After putting my headphones in and listening to music. The high pitched noise is now coming from the headphones instead? And barely any noise from the motherboard like before.. not sure what to think now. Totally confused.
