- 29 Aug 2011
Afternoon for weeks now there has been a high pitched noise coming from my PC. It is like a dog whistle and has caused ringing in my ear. It occurs when windows is loading not before and then remains in idle or full load.
I have removed all graphics cards, ram, hard drives one by one testing for the noise. Changed all case fans / cpu fans for silent ones. PSU when removed from case and used doesnt make the noise. I was in the process of rma for the motherboard, used my friends spare and still the noise would occur as it seems to be coming from the cpu chip (i have changed the heat sink and fan but still the same noise)
Ive tried turning off all cpu bios settings to do with energy saving / efficiency - still the same noise. I'm pretty much left with only the cpu chip left to change which will need a rma but can a cpu chip make a high pitched noise that is so damaging i cant keep it on for more than 5 minutes ?!?!
Model Name : GA-Z68A-D3-B3(rev. 1.0)
M/B Rev : 1.0
BIOS Ver : F2
VGA Brand : ATi Model : HD 6870
CPU Brand : Intel Model : i5 2500k Speed : 3.30 GHz
Operation System : Win 7 64-bit SP :
Memory Brand : Corsair Type :
Memory Size : 2x4GB Speed : 1333 GHz
Power Supply : 650 W
Antec ultra silent 650W power supply.
M/B Rev : 1.0
BIOS Ver : F2
Ive read about coil whine which is my only hope now but the fan on the PSU is silent.
