High pitched revving
16 Oct 2007
UK
Hi motors,
Ford Focus mk2, just passed MOT a few days ago
Driving home from work today, noticed a high pitched noise when revving the car.
When clutch is down and idling, couldn't really hear the noise. Revving anything past 2k and you could hear it loud.
I tried revving in neutral but you can just make the noise out. Much louder when in gear.
Any ideas?
https://drive.google.com/file/d/1WPiOLtXKLhGnB-An69z2awT7skibW9Cl/view?usp=sharing
Cambelt changed 20k ago
Oil regularly checked - top end does sound a bit on rough on the video but whilst driving, usually sounds smooth!
Just spotted the power steering fluid is near empty and some fluid on the pipe. Hopefully just a new pipe set else the PAS motor + pipes looks stupidly expensive!!
Our ford connect van at work makes a sound similar to that but a whole lot worse, Power steering is knackered on it so I'd say that's your problem.
