- 3 May 2022
- Ukraine
Hello! I have a 12v CA lead acid battery, when charging it using a smart charger, at the point where the indicator says it’s close to full, there is a faint high-pitched electronic sound ( like from voltage) - is this bad for the battery and should I stop charging at this point? After stopping charging, the battery showed 12.7v for a bit, then went to 12.6 - thanks in advance!
