High Refresh Rate Panels and Displays - A road-map and round-up
Some great info there cheers Baddass. It seems that if you want to go 2560x1440 ~144hz the panels that are out now are going to be pretty much around for a while.
I did find something on the Google last night about a mooted Acer 32 inch 1440p high refresh rate monitor, it must be tied in with that 31.5" VA Panel that AUO are working on...
Good stuff!
It's a real shame we are still so hamstrung by DP 1.2. They must be having real problems developing DP 1.3/1.4 TCon's if its taking them this long.
Good stuff!
Didn't realise DP1.2 was a problem for 1440. I thought it only became an issue at 4k if you want more than 60fps?
Wish someone would make a smaller high refresh 1440p/ips. Limited room where my pc is, so can't really go above 24" :(.
Other than that, meh. So still stuck with the same panel,that is a lottery whether you get a good one and still no oled monitors.
So disappointing 4K higher refresh rate are so far away. If things stay the way they are I recon 4K TV's with low latency will consume the high end monitor market.
NEC PA322UHD-BK-2 supports refresh up to 120Hz in *lower* resolutions (where bandwidth of DP 1.2 is sufficient). So it could definitely drive its 4K panel at 120Hz at the least - its only the DP interface which appears to be the bottleneck, not the panel tech.
Is there an engineering article anywhere about this 4K120 problem? I would like to know exactly where the roadblock is... we've had DP 1.3 for a year now and GPUs with display controllers supporting 1.4 about half that.
AFAIK DP 1.3 exists on paper only (and in GPU theoretical "driver support"), and maybe in some prototype lab demos. Nobody managed to mass-produce stable working DP 1.3 controllers and cables yet, not to say 1.4
I don't know much details, but suspect greatly raised bandwidth was made it too susceptible to interference (which was somewhat in issue even in DP 1.2).
Bandwidth required to drive 4K@120Hz is quite massive - to give you idea, it would occupy majority of Thunderbolt 3 connection (and Thunderbolt 2 is not enough). Unlike DP 1.3, mainstream Thunderbolt 3 hardware does exist already and can be used to produce 4K@120Hz display - but monitor manufacturers are probably reluctant because adoption of TB3 ports on PC side is still low...
Another real possibility is to use DP aggregation to use two DP 1.2 connections to drive single monitor. This was actually done by Dell for UP2715K to drive 5K with two DP 1.2 cables & ports. But nobody else did it - again, probably because solution is too non-mainstream and fragile ;)
Doesn't aggregation mean the screen ends up being 2 panels? With each link controlling half the pixels.
Not necessary, it still can be same panel - but yes, each cable will drive half of it. It still could be fully synchronized refresh, when one controller is "slaved" to another.
A lot of even DP 1.2 4K 60Hz panels are currently this way, where they split links from single cable to drive each half - for example M320QAN01 panel used in Acer XB321HK, BenQ BL3201PT and others.
