High-Resolution Audio
I'm unaware of any group streaming in HD.
HDTracks do have some in HD, though it's hardly a brilliant range, and be aware that some have commented that some of the tracks are just normal CD (16/44.1) that has been upsampled.
Also if you want something to read...
http://archimago.blogspot.ca/2014/06/24-bit-vs-16-bit-audio-test-part-i.html
http://archimago.blogspot.de/2014/06/24-bit-vs-16-bit-audio-test-part-ii.html
Cliffs =
In a naturalistic survey of 140 respondents using high quality musical samples sourced from high-resolution 24/96 digital audio collected over 2 months, there was no evidence that 24-bit audio could be appreciably differentiated from the same music dithered down to 16-bits using a basic algorithm (Adobe Audition 3, flat triangular dither, 0.5 bits).
Big thread:
http://www.head-fi.org/t/415361/24bit-vs-16bit-the-myth-exploded
Why dont they produce more High-Resolution Audio at 24 bit/ 96kHz music
The problem is the sound quality that made in the industry these days is so bad , if it was ported onto a hi-res format it would show how bad it really was. you wouldn't buy it . The music studios have literally got to start from senior management level and force changes in the industry to make it viable.
Its the reason why its mosty older albums that get released. With the odd exception due to the fact the sound engineers knew what they were doing.
I think sound engineers still know what they're doing. The problem is that studio time and their wages are paid for by producers who have a different agenda. He who pays the piper calls the tune. There's less of a problem with over-compression outside of pop and rock.
I tried tidal trial the other week
Music's seems better quality but I decided to cancel at end of trial reasons being £19.99 a month is a lot when the app is fairly buggy. It's slow to respond to commands or just does not respond at all, plus if they expect me to pay 19.99 a month I expect at least a months free trial to make my mind up!
Same its too much at twice the price of Spotify. I generally buy cd's and rip to FLAC even if the difference is negligible its often cheaper or at least the same price this way.
I probably cant tell the difference most of the time as im sure a lot of you cant from 320kbs lossy, but that's not the point. ITunes/mp3 albums should be a good bit cheaper I think.
What on earth gives you this impression?
It's pretty hard to make something sound 'bad' these days with the rise of pro-sumer technology. At home with a half decent mic, soundcard and computer it's possible to record something in a way that you wouldn't have been able to dream of 20-30 years ago. It's for this reason many of the bigger studio complexes are struggling to stay afloat!
The reason why high resolution audio isn't popular is primarily down to:
1) Size/cost/quality ratio
2) Actual need for it
With regards to point 1, music these days is consumed in a very different way - where as in the past it was listened to with 'intent' (think hifi's of the 70's and 80's), these days it's much more of a background activity whilst doing something else. As such, the outright quality isn't the be all end all. Given the choice of having 10 high quality tracks to listen to versus 100 slightly lower quality tracks, I'm willing to bet most people would go for quantity over quality. People generally don't spend that much money on playback systems compared to years gone by, so again the source material isn't as important since the playback kit won't highlight the compression artifacts etc in the same way.
That said, the source material in the main is being recorded, produced and mastered in much the same way as it always has, there's just been a move towards crushed dynamics with certain styles of music. This is beginning to end though - we're starting to see greater dynamic range in quite a few albums. Daft Punk's latest is a good example.
Point 2 - as discussed elsewhere there simply isn't a need for 96/24 unless you're recording audio. It offers NO BENEFIT whatsoever to a listener. There's a bit of a misconception with understanding how digital audio works. In order to visualise the A>D process, more often than not a 'staircase' is shown using samples, and the higher the sample rate the 'finer' the staircase is. Unfortunately this is very misleading.
http://www.xiph.org/video/vid2.shtml
Have a watch of this video, it's a brilliant explanation of how digital audio actually works in the real world, and although it goes on to some other things (dither etc) which aren't that relevant for a listener, hopefully the first part will put into perspective why 24 bits aren't actually that useful if you're just a listener. :)
Because there isn't any evidence that it sounds any different to ordinary CDs.... aside from dubious claims from the golden ear brigade
Which tin cans are you using ? :p Done properly 24/96 will beat cd all day long.
it's probably more apparent using a proper headphone set-up than speakers mind
I'll trust a study over some random guys on audio forums, it's like the same myth as lossless audio.
The Emperor has no clothes more like....
It really doesn't seem to be the case at all, if there was an obvious difference then it could be shown in a test, so far there doesn't appear to be.
