Hi, I recently got my new Ryzen build going, and ran a quick AIDA64 test and the boost kicked in to 4.2ghz, but the temps immediately hit 90C. This reduced the clock speeds to 4ghz, but still 80C. The speeds would then fluctuate between 3.8-4Ghz while hovering around 80C.
I've only run WoW so far, and had 51C running at 30% CPU usage which seems okay, but the 80-90C constant temps seems a bit high to me?
I'm using the stock cooler with Thermal Grizzly Kryonaut, but before I consider a new cooler, I want to make sure there's no weird settings to check in my BIOS (I'm running latest as of today), or if I should consider undervolting (how do I undervolt? Never had to change voltages before).
I'm coming from an overclock 3570k with a CM Hyper 212 Evo that could keep it steady at 4.4ghz under 65C at all times, so 80-90 feels very high. The monitored temps are coming from both MSI Afterburner and Ryzen Master.
