High sound quality in ear earphones advice... options/recommendations please
  • Thread starter Thread starter Deleted member 251651
  • Start date Start date
D
Hi peoples,
I'm after some in ear earphones, but don't really know what to buy.... they will be used on my pc with an Asus X670E Hero motherboard, so want something which would make the most of what I have.........
ROG SupremeFX 7.1 Surround Sound High
Definition Audio CODEC ALC4082
- Impedance sense for front and rear
headphone outputs
- Supports: Jack-detection,
Multi-streaming, Front Panel Jack-retasking
- High quality 120 dB SNR stereo playback
output and 113 dB SNR recording input
- Supports up to 32-Bit/384 kHz playback"
Audio Features
- SupremeFX Shielding Technology
- ESS® ES9218 QUAD DAC
- Gold-plated audio jacks
- Rear optical S/PDIF out port
- Premium audio capacitors
- Audio cover
They would need to meet the following criteria and be of high sound quality:-
1. Around £150 or less, cheaper the better
2. Without microphone
3. Ideally wired as I dont want to be charging them, UNLESS they come with an option, where you can attach and detach the wire and use them wired whilst charging and or wirelessly.
4. Need to have excellent sound quality
5. Noise Cancelling
6. Ideally white as my pc is white, but not too fussed.....
Appriciate any suggestions/help, thanks.
